[GRASS-dev] Re: [GRASS GIS] #254: wxpython Layer Manager: higher
raster hides the lower
Glynn Clements
glynn at gclements.plus.com
Tue Aug 12 17:59:07 EDT 2008
GRASS GIS wrote:
> SVN trunk now produces GRASS 7 (and a lot is broken due to heavy
> development).
There shouldn't really be all that much broken. In particular, the GUI
(both gis.m and wxgui) should be unaffected.
The modules which are known to be broken (and are likely to stay
broken for a while or even permanently) are those which interact with
the user via a terminal or by using the mouse with XDRIVER.
Anything which runs without interaction (i.e. anything used internally
by the GUI or run from the GUI without using run_xterm or
guarantee_xmon) is supposed to work.
[Both of those features may as well be removed from gis.m in 7.x.
Anything which requires them is dead.]
Of course, with so many changes being made, bugs may get introduced,
but those can usually be fixed quickly when they are pointed out (and
the time taken to identify such bugs depends heavily upon the amount
of testing they get).
