[GRASS-dev] Re: testing d.thematic.area - problem
William Kyngesburye
woklist at kyngchaos.com
Tue Aug 12 14:01:48 EDT 2008
On Aug 12, 2008, at 12:40 PM, Michael Barton wrote:
> Moritz,
> I just installed your tarball, did a make clean, make, and make
> install.
> I got the same error when I tried to run d.thematic.area
> GRASS 6.4.svn (Spearfish60_test):~ > d.thematic.area
> dyld: lazy symbol binding failed: Symbol not found: _G_gisinit
> Referenced from: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/
> bin/d.thematic.area
> Expected in: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/lib/
> libgrass_gis.dylib
> dyld: Symbol not found: _G_gisinit
> bin/d.thematic.area
> libgrass_gis.dylib
> Trace/BPT trap
Maybe something is wrong with your libgrass_gis? What does this say:
nm -mjg /Applications/Grass/GRASS-6.4.app/Contents/MacOS/lib/
libgrass_gis.dylib | grep _G_gisinit
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do if
you ARE a maniacally depressed robot? No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
