[GRASS-dev] Re: testing d.thematic.area - problem
Michael Barton
michael.barton at asu.edu
Tue Aug 12 14:06:59 EDT 2008
On Aug 12, 2008, at 11:01 AM, William Kyngesburye wrote:
> On Aug 12, 2008, at 12:40 PM, Michael Barton wrote:
>> Moritz,
>> I just installed your tarball, did a make clean, make, and make
>> install.
>> I got the same error when I tried to run d.thematic.area
>> GRASS 6.4.svn (Spearfish60_test):~ > d.thematic.area
>> dyld: lazy symbol binding failed: Symbol not found: _G_gisinit
>> Referenced from: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/
>> bin/d.thematic.area
>> Expected in: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/lib/
>> libgrass_gis.dylib
>> dyld: Symbol not found: _G_gisinit
>> bin/d.thematic.area
>> libgrass_gis.dylib
>> Trace/BPT trap
> Maybe something is wrong with your libgrass_gis? What does this say:
> nm -mjg /Applications/Grass/GRASS-6.4.app/Contents/MacOS/lib/
> libgrass_gis.dylib | grep _G_gisinit
Nothing (i.e., nothing is returned)
Everything else seems to launch fine. The d.thematic.area GUI won't
even launch--in wxpython or in tcltk.
Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin] You think you have problems? What are you supposed to do
> if you ARE a maniacally depressed robot? No, don't try and answer,
> I'm 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
