[GRASS-dev] A couple of r.colors ideas
Wed Aug 13 04:23:34 EDT 2008
Markus Neteler wrote:
> >>> Added as r.colors.out.
> >> In trunk? Backported to develbranch_6?
> > Trunk.
> > It may need a G_find_cell2() call to work in 6.4. In 7.x, any libgis
> > functions which deal with existing maps should accept "" for the
> > mapset argument, eliminating the need for explicit G_find_* calls in
> > most cases.
> > On that front, r32633 should probably be back-ported. It fixes the
> > case of passing qualified names to G__open[_misc] and G_read_colors().
> > [Colour tables need special treatment because of the colr2 feature.
> > The g3d library has a similar feature which is both more general and,
> > AFAICT, seriously borked.]
> So,
> http://trac.osgeo.org/grass/changeset/32633
> should we do this? Any side effects?
That should be safe.
There's also r32717 (which requires r32715) and r32735. Both of those
should be safe (r32715 definitely is, and can be committed
independently of the other two).
I'm now reasonably sure that all library functions which accept a name
and mapset will accept an empty mapset ("") with either a qualified or
unqualified name.
The only exceptions are G__file_name() and G__file_name_misc(), which
need to be able to construct filenames for maps which are in the
process of being created, so they can't use G_find_file() etc.
