[GRASS-dev] default icon set in wxGUI
Martin Landa
landa.martin at gmail.com
Wed Aug 13 12:23:54 EDT 2008
2008/8/13 Glynn Clements <glynn at gclements.plus.com>:
>> Example: in digitizer half of the tools are not
>> visible unless you manually extend the window width.
> That's a bug (or maybe a limitation in wxPython, but I don't think
> so). A window's minimum size should be sufficient for all of its
> subwindows to obtain their minimum size and to be visible.
For map display and layer manager is used
http://docs.wxwidgets.org/stable/wx_wxauimanager.html#wxauimanager
SetSizerAndFit() is not enough here, I will look at this issue later.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
