[GRASS-dev] iostream lib and r.terraflow/r.viewshed
Laura Toma
ltoma at bowdoin.edu
Wed Aug 13 17:29:21 EDT 2008
I added r.viewshed to grass-addons, and deleted it from the trunk.
-Laura
On Aug 13, 2008, at 4:47 PM, Paul Kelly wrote:
> On Wed, 13 Aug 2008, Laura Toma wrote:
>> Unfortunately I cannot reproduce the compile errors, so I cannot
>> be of much help.
> I wondered if you might be able to help with advice on the C++
> headers. From the compile errors it seems to me that the problem is
> a lack of a definition for the strcpy() function in the
> ami_stream.h header. I suspect that adding
> #include <cstring>
> (thanks to Martin for the hint about the C++ header names) would
> solve the compilation errors, but I'm not sure if anybody with
> access to a problem system has tried it out yet - but I'm thinking
> of maybe just going ahead and making the change as it seems so
> appropriate.
>> I added r.viewshed in grass_trunk/raster/. It compiles and works
>> for me. Looking forward to comments.
> Should it maybe go in grass-addons rather than trunk for now?
> Paul
