[GRASS-dev] Re: [GRASS GIS] #259: wxGUI: visualization problems
with multiple rasters and vectors. not stable bug...
trac at osgeo.org
Sun Aug 17 08:53:27 EDT 2008
#259: wxGUI: visualization problems with multiple rasters and vectors. not stable
bug...
Reporter: giohappy | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: Linux | Cpu: x86-32
Comment (by giohappy):
Thanks Michael.
It seems to work now. Let's keep this open for one day more, so I can do
more tests.
Two remarks:
1 - about the FIRST CASE (add a raster and a point, and then add another
raster between the twos), it needs the "re-render" button to be used,
because the "display map" isn't enough: the new raster hides the points.
Why don't we use the same method of all the other GIS: when one adds a
layer, the map is automatically rebuilt. It would avoid having to push the
"display" and the "re-render" buttons every time...
It could be in option in the preferences.
2 - the "fcolor" option of polygons in tcltk permits to choose the "None"
value to do not make the polygons filled. This option doesn't appear in
wxGUI, in which one is obligated to choose a color. The same for lines...
Ticket URL: <http://trac.osgeo.org/grass/ticket/259#comment:4>
