[GRASS-dev] get_row.c: output north/east values? G__.window structure
Markus Neteler neteler at osgeo.org
Tue Aug 26 15:44:14 EDT 2008
On Tue, Aug 26, 2008 at 8:52 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> Does below makes sense for v.extrude?
> That causes an infinite loop, as you're skipping the k++ at the
yes, this was my problem indeed (but not in every run).
> bottom. I suggest changing it to a for loop.
> Also, the third test should probably be testing voffset_next rather
> than voffset_curr.
err, would you mind to submit these suggestion?
thanks
Markus
