[GRASS-dev] get_row.c: output north/east values? G__.window structure
Tue Aug 26 17:23:22 EDT 2008
Markus Neteler wrote:
> >> Does below makes sense for v.extrude?
> > That causes an infinite loop, as you're skipping the k++ at the
> yes, this was my problem indeed (but not in every run).
It can only happen when -t is used (and when there are nulls).
> > bottom. I suggest changing it to a for loop.
> > Also, the third test should probably be testing voffset_next rather
> > than voffset_curr.
> err, would you mind to submit these suggestion?
Done.
