[GRASS-dev] get_row.c: output north/east values? G__.window structure
Wed Aug 27 08:53:38 EDT 2008
Markus Neteler wrote:
> >> >> Does below makes sense for v.extrude?
> >> > That causes an infinite loop, as you're skipping the k++ at the
> >> yes, this was my problem indeed (but not in every run).
> > It can only happen when -t is used (and when there are nulls).
> >> > bottom. I suggest changing it to a for loop.
> >> > Also, the third test should probably be testing voffset_next rather
> >> > than voffset_curr.
> >> err, would you mind to submit these suggestion?
> > Done.
> Thanks. However, now it segfaults:
Right; it needs to reproduce the loop termination tests. Try r33118.
