[GRASS-dev] get_row.c: output north/east values? G__.window structure
Markus Neteler neteler at osgeo.org
Wed Aug 27 10:17:46 EDT 2008
On Wed, Aug 27, 2008 at 2:53 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> >> Does below makes sense for v.extrude?
>> >> > That causes an infinite loop, as you're skipping the k++ at the
>> >> yes, this was my problem indeed (but not in every run).
>> > It can only happen when -t is used (and when there are nulls).
>> >> > bottom. I suggest changing it to a for loop.
>> >> > Also, the third test should probably be testing voffset_next rather
>> >> > than voffset_curr.
>> >> err, would you mind to submit these suggestion?
>> > Done.
>> Thanks. However, now it segfaults:
> Right; it needs to reproduce the loop termination tests. Try r33118.
The segfault is solved now (backported to 6.4.svn).
Still no faces any more... possibly unrelated?
The last one with sampling might be v.drape:
GRASS 6.4.svn (nc_spm_07):~/grass64 > g.region vect=roadsmajor
GRASS 6.4.svn (nc_spm_07):~/grass64 > v.drape roadsmajor out=roads_3d
rast=elevation
WARNING: Current region does not include the entire input vector map
         <roadsmajor>
WARNING: Elevation raster map <elevation> does not cover the entire area of
         the input vector map <roadsmajor>.
The first warning is surprising given the g.region command.
In the code there are also snippets like
                    estimated_elevation = scale * G_get_raster_sample(fdrast,
Help kindly appreciated...
thanks
Markus
