[GRASS-dev] GRASS_BATCH_JOB and GISRCRC
Markus Neteler neteler at osgeo.org
Wed Aug 27 11:27:04 EDT 2008
I would like to submit the following change to facilitate the use
of GRASS on clusters/in parallel jobs:
Index: lib/init/init.sh
--- lib/init/init.sh    (revision 33097)
+++ lib/init/init.sh    (working copy)
@@ -159,7 +159,11 @@
 export GIS_LOCK
 # Set the global grassrc file
-GISRCRC="$HOME/.grassrc6"
+if [ -n "$GRASS_BATCH_JOB" ] ; then
+       GISRCRC="$HOME/.grassrc6.`uname -n`"
+else
+       GISRCRC="$HOME/.grassrc6"
+fi
 # Set the session grassrc file
 if [ "$MINGW" ] ; then
This change will render GISRCRC individual if running GRASS
in parallel on a series of machines.
For a "normal" user the behavior is as before.
Any objections?
Markus
