[GRASS-dev] 6.4rc1
Glynn Clements
glynn at gclements.plus.com
Tue Dec 2 00:25:07 EST 2008
Paul Kelly wrote:
> >> so what remains todo befor 6.4rc1? IMO lib API and module list should be
> >> frozen at that point, which means creating releasebranch_6_4. No need to
> > I also added to the list nviz_cmd module. I am not sure about its
> > name. Any ideas?
> > nviz.cmd
> What about reviving the d.3d name? Or something that makes the
> functionality more obvious than nviz.cmd? I kind of think it should be a
> d.* command because it is really a display command, although different
> from most of the others...
I don't think that it should be a d.* command; that prefix should be
reserved for modules which use the raster library.
