[GRASS-dev] [GRASS GIS] #391: SQLite driver doesn't complain enough
with stupid mistakes
trac at osgeo.org
Fri Dec 5 21:18:49 EST 2008
#391: SQLite driver doesn't complain enough with stupid mistakes
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Database | Version: svn-develbranch6
Keywords: sqlite | Platform: Linux
Cpu: Unspecified |
Using the SQLite driver, the following v.db.addcol command runs without
error:
G64:spearf> g.copy vect=archsites,tmp_arch
G64:spearf> v.db.addcol tmp_arch column='x double y double'
(typo, no comma between column defs)
but when you try and do something with it you get an error:
G64:spearf> v.info -c tmp_arch
Displaying column types/names for database connection of layer 1:
WARNING: SQLite driver: unable to parse decltype: double y double
WARNING: SQLite driver: column 'x', SQLite type 2 is not supported
INTEGER|cat
CHARACTER|str1
a fatal error from v.db.addcol or from the driver would be nice.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/391>
