[GRASS-dev] Re: [GRASS GIS] #355: ps.map generates invalid postscript when vlegend item does not appear on map
GRASS GIS trac at osgeo.org
Fri Dec 5 21:02:49 EST 2008
map
  Reporter:  scottygamm        |       Owner:  hamish
      Type:  defect            |      Status:  closed
  Priority:  minor             |   Milestone:  6.4.0
 Component:  ps.map            |     Version:  6.3.0
Resolution:  fixed             |    Keywords:
  Platform:  MSWindows CygWin  |         Cpu:  x86-32
Comment (by hamish):
 Replying to [comment:5 hamish]:
 > I also fixed the vector legend bug reported by Casey Vandenberg on Nov
 20 where it wouldn't let you place the vector legend to the left of the
 map box. Now you can go as far as the left margin. The right side of the
 legend (for multicolumn) is still rather unconstrained, I've left it as
 not starting a new column past the right side of the map box, which seems
 like a fair compromise. Feel free to post a patch doing that better if you
 can figure out how.. I don't think it is easily possible to improve on the
 current way.
 actually it was easy. I've now added a new vlegend "span" command to let
 you set the legend column spacing.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/355#comment:6>
