[GRASS-dev] r.watershed2 with MFD
Glynn Clements
glynn at gclements.plus.com
Mon Dec 8 04:22:19 EST 2008
Markus Metz wrote:
> I can not commit to grass7 (no write access or too stupid), therefore I
> want to ask you developers if one of you could get the mfd module
> including .svn entries developed against grass7 from here
> http://markus.metz.giswork.googlepages.com/r.watershed.mfd.tar.gz
> and commit the changes to grass7. The code has been indented with
> grass_indent.sh
> Single flow direction method is unaltered.
> There is one global change in r.watershed, flow accumulation is now
> DCELL, no longer CELL.
I've committed this as r34789, and fixed a minor bug (missed
opt16/opt17 renumbering) in r34790.
I note a couple of compile warnings:
make[1]: Entering directory `/usr/local/src/grass/svn/raster/r.watershed/seg'
close_maps.c: In function `close_maps':
close_maps.c:103: warning: passing arg 1 of `cseg_close' from incompatible pointer type
close_maps.c:8: warning: unused variable `value'
no_stream.c: In function `no_stream':
no_stream.c:89: warning: passing arg 2 of `cseg_put' from incompatible pointer type
The first one is due to "wat" having been changed from CSEG to DSEG;
presumably it also needs a change from cseg_close to dseg_close?
The second is due to "value" having been changed from CELL to DCELL,
but still being stored in "haf" which is CSEG. The value being stored
is actually an integer; it appears that "value" was simply being used
as a temporary variable, so I presume that it would suffice to do:
- value = basin_num - 1;
- cseg_put(&haf, &value, row, col);
+ CELL tmp = basin_num - 1;
+ cseg_put(&haf, &tmp, row, col);
However, I don't want to make these changes without checking.
