[GRASS-dev] Re: [GRASS GIS] #391: SQLite driver doesn't complain enough with stupid mistakes
GRASS GIS trac at osgeo.org
Tue Dec 9 05:55:27 EST 2008
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  Database  |     Version:  svn-develbranch6
Resolution:            |    Keywords:  sqlite
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by neteler):
 If desired in the SQLite driver, only SQL parsing might solve the problem
 (complicated).
 For now, in r34809 I have added a check to v.db.addcol to reject odd
 column definitions comparing number of tokens against number of desired
 columns to be created.
 Someone needs to forward-port to trunk/Python this test if desired.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/391#comment:1>
