[GRASS-dev] Re: [GRASS GIS] #391: SQLite driver doesn't complain enough with stupid mistakes
GRASS GIS trac at osgeo.org
Tue Dec 9 06:53:43 EST 2008
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  Database  |     Version:  svn-develbranch6
Resolution:            |    Keywords:  sqlite
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:1 neteler]:
 > If desired in the SQLite driver, only SQL parsing might solve the
 problem (complicated).
 > For now, in r34809 I have added a check to v.db.addcol to reject odd
 column definitions comparing number of tokens against number of desired
 columns to be created.
 So presumably it won't accept column types which contain spaces ("double
 precision", "character varying", "varchar (50)", etc)?
 > Someone needs to forward-port to trunk/Python this test if desired.
 Not desired.
Ticket URL: <http://trac.osgeo.org/grass/ticket/391#comment:2>
