[GRASS-dev] Re: G_percent() usage;
Glynn Clements
glynn at gclements.plus.com
Wed Dec 10 03:03:47 EST 2008
Hamish wrote:
> > G_percent() is needed after the loop has finished, otherwise "100%\n" is
> > never printed, and the GUI progress bar* stalls at almost-complete.
> > consider the order of what happens here, and when will
> > row==nrows (ie 100%):
> > for (row = 0; row < nrows; row++) { printf("row=%d\n", row); }
> > G_percent(row, nrows, 2);
> ok, I see what you did now with
> G_percent(row+1, nrows, 2);
> in the loop. But I think that's wrong. For one thing it incorrectly skips
> 0% done. (typically harmlessly corrected in rounding, but still
> incorrect..)
> maybe it's just me, but I prefer the historical way.
IMHO, we want 0% at the very beginning of the operation, and we need
100% at the end.
Ergo, if there are N iterations, G_percent() needs to be called N+1
times (0 to N inclusive), which means that there must be two calls:
one inside the loop, one outside.
For that, you can either call it with 0 before the loop and row+1 at
the end of each iteration, or with row at the start of each iteration
and rows after the loop. I suggest the latter.
