[GRASS-dev] r.watershed2 with MFD
Markus Metz
markus.metz.giswork at googlemail.com
Wed Dec 10 06:02:52 EST 2008
Glynn, can you please apply the attached patch for r.watershed in
grass/trunk? It contains last fixes for MFD support including usable (I
hope) basin determination.
Thank you,
Markus M
diff -ruP r.watershed/front/main.c r.watershed.mfd/front/main.c
--- r.watershed/front/main.c 2008-12-09 09:26:57.000000000 +0100
+++ r.watershed.mfd/front/main.c 2008-12-09 09:57:39.000000000 +0100
@@ -368,16 +368,12 @@
if (!flag_sfd->answer && opt16->answer) {
strcat(command, " conv=");
- strcat(command, "\"");
strcat(command, opt16->answer);
if (flag_seg->answer && opt17->answer) {
strcat(command, " mb=");
strcat(command, opt17->answer);
G_debug(1, "Mode: %s", flag_seg->answer ? "Segmented" : "All in RAM");
diff -ruP r.watershed/front/r.watershed.html r.watershed.mfd/front/r.watershed.html
--- r.watershed/front/r.watershed.html 2008-12-09 09:26:57.000000000 +0100
+++ r.watershed.mfd/front/r.watershed.html 2008-12-09 10:19:05.000000000 +0100
@@ -224,9 +224,9 @@
As a result, depressions and obstacles are overflown with a gracefull
flow convergence before the overflow. The convergence factor causes flow
accumulation to converge more strongly with higher values. The supported
-range is 1 to 10, recommended is a convergence factor of 5. Although
-basins and half-basins are calculated when using MFD, it is strongly
-recommended to use SFD for basin and half-basin determination.
+range is 1 to 10, recommended is a convergence factor of 5. If many
+small sliver basins are created with MFD, setting the convergence factor
+to a higher value can reduce the amount of small sliver basins.
<br>See example below with the North Carolina dataset for using MFD mode.
<h4>In-memory mode and disk swap mode</h4>
@@ -485,4 +485,4 @@
Markus Metz <markus.metz.giswork at gmail.com>
<p>
-<i>Last changed: $Date: 2008-12-08 10:11:19 +0100 (Mon, 08 Dec 2008) $</i>
+<i>Last changed: $Date: 2008-12-09 10:18:19 +0100 (Tue, 09 Dec 2008) $</i>
diff -ruP r.watershed/ram/do_cum.c r.watershed.mfd/ram/do_cum.c
--- r.watershed/ram/do_cum.c 2008-12-09 09:26:56.000000000 +0100
+++ r.watershed.mfd/ram/do_cum.c 2008-12-09 09:59:49.000000000 +0100
@@ -41,8 +41,9 @@
valued = value - valued;
wat[SEG_INDEX(wat_seg, dr, dc)] = valued;
+ valued = ABS(valued) + 0.5;
is_swale = FLAG_GET(swale, r, c);
- if (is_swale || ABS(valued) >= threshold) {
+ if (is_swale || ((int)valued) >= threshold) {
FLAG_SET(swale, dr, dc);
else {
@@ -83,7 +84,7 @@
int r, c, dr, dc;
CELL is_swale;
- DCELL value, valued, value_sfd;
+ DCELL value, valued;
int killer, threshold, count;
int mfd_cells, astar_not_set;
@@ -94,14 +95,15 @@
double prop;
int workedon;
- G_message(_("SECTION 3: Accumulating Surface Flow with MFD."));
+ G_message(_("SECTION 3: Accumulating Surface Flow with MFD"));
+ G_debug(1, "MFD convergence factor set to %d.", c_fac);
/* distances to neighbours */
dist_to_nbr = (double *)G_malloc(sides * sizeof(double));
weight = (double *)G_malloc(sides * sizeof(double));
for (ct_dir = 0; ct_dir < sides; ct_dir++) {
- /* get r, c (upr, upc) for neighbours */
+ /* get r, c (r_nbr, c_nbr) for neighbours */
r_nbr = nextdr[ct_dir];
c_nbr = nextdc[ct_dir];
/* account for rare cases when ns_res != ew_res */
@@ -111,8 +113,6 @@
dist_to_nbr[ct_dir] = dx + dy;
else
dist_to_nbr[ct_dir] = sqrt(dx * dx + dy * dy);
flag_clear_all(worked);
@@ -133,7 +133,7 @@
c = astar_pts[killer].c;
dc = astar_pts[killer].downc;
value = wat[SEG_INDEX(wat_seg, r, c)];
- value_sfd = wat[SEG_INDEX(wat_seg, dr, dc)];
+ valued = wat[SEG_INDEX(wat_seg, dr, dc)];
/* disabled for MFD */
/* if (ABS(value) > threshold)
@@ -150,7 +150,7 @@
ele = alt[SEG_INDEX(alt_seg, r, c)];
/* this loop is needed to get the sum of weights */
r_nbr = r + nextdr[ct_dir];
c_nbr = c + nextdc[ct_dir];
weight[ct_dir] = -1;
@@ -160,7 +160,6 @@
in_val = FLAG_GET(worked, r_nbr, c_nbr);
if (in_val == 0) {
ele_nbr = alt[SEG_INDEX(alt_seg, r_nbr, c_nbr)];
- /* to consider neighbours with equal ele, change if() */
if (ele_nbr < ele) {
weight[ct_dir] =
mfd_pow(((ele -
@@ -240,16 +239,13 @@
if (ABS(prop - 1.0) > 5E-6f) {
- G_warning(_("Cumulative proportion not 1.0 but %f"),
+ G_warning(_("MFD: cumulative proportion of flow distribution not 1.0 but %f"),
prop);
- valued =
- ABS(value_sfd) +
- ABS(value) * weight[np_side] / sum_weight;
if (mfd_cells < 2) {
- valued = value_sfd;
if (value > 0) {
if (valued > 0)
valued += value;
@@ -270,7 +266,7 @@
- if (is_swale || (int)valued > threshold) {
else {
@@ -282,8 +278,8 @@
G_percent(count, do_points, 1); /* finish it */
if (workedon)
- G_message(_("A * path already processed: %d of %d"), workedon,
- do_points);
+ G_warning(_("MFD: A * path already processed when distributing flow: %d of %d"),
+ workedon, do_points);
G_free(astar_pts);
diff -ruP r.watershed/ram/no_stream.c r.watershed.mfd/ram/no_stream.c
--- r.watershed/ram/no_stream.c 2008-12-09 09:26:56.000000000 +0100
+++ r.watershed.mfd/ram/no_stream.c 2008-12-08 16:00:07.000000000 +0100
@@ -6,7 +6,7 @@
int r, rr, c, cc, uprow = 0, upcol = 0;
double slope;
CELL downdir, asp_value, hih_ele, new_ele, aspect;
- DCELL value, max_drain; /* flow acc is now DCELL */
+ DCELL dvalue, max_drain; /* flow acc is now DCELL */
SHORT updir, riteflag, leftflag, thisdir;
while (1) {
@@ -16,14 +16,13 @@
if (r >= 0 && c >= 0 && r < nrows && c < ncols) {
aspect = asp[SEG_INDEX(asp_seg, r, c)];
if (aspect == drain[rr][cc]) {
- value = wat[SEG_INDEX(wat_seg, r, c)];
- /* here is the reason why MFD basins differ from SFD basins */
- if (value < 0)
- value = -value;
- if ((value - max_drain) > 5E-8f) { /* floating point comparison problem workaround */
+ dvalue = wat[SEG_INDEX(wat_seg, r, c)];
+ if (dvalue < 0)
+ dvalue = -dvalue;
+ if ((dvalue - max_drain) > 5E-8f) { /* floating point comparison problem workaround */
uprow = r;
upcol = c;
- max_drain = value;
+ max_drain = dvalue;
diff -ruP r.watershed/seg/close_maps.c r.watershed.mfd/seg/close_maps.c
--- r.watershed/seg/close_maps.c 2008-12-09 09:26:58.000000000 +0100
+++ r.watershed.mfd/seg/close_maps.c 2008-12-08 15:52:57.000000000 +0100
@@ -5,7 +5,7 @@
struct Colors colors, logcolors;
int r, c;
- CELL is_swale, value;
+ CELL is_swale;
double dvalue;
struct FPRange accRange;
DCELL min, max;
@@ -100,7 +100,7 @@
/* error in gislib.a
G_free_colors(&colors);
- cseg_close(&wat);
+ dseg_close(&wat);
if (ls_flag) {
dseg_write_cellfile(&l_s, ls_name);
dseg_close(&l_s);
diff -ruP r.watershed/seg/do_cum.c r.watershed.mfd/seg/do_cum.c
--- r.watershed/seg/do_cum.c 2008-12-09 09:26:58.000000000 +0100
+++ r.watershed.mfd/seg/do_cum.c 2008-12-09 10:00:27.000000000 +0100
@@ -13,6 +13,7 @@
G_message(_("SECTION 3: Accumulating Surface Flow with SFD."));
count = 0;
if (bas_thres <= 0)
@@ -87,7 +88,7 @@
int r, c, dr, dc;
CELL is_swale;
POINT point;
@@ -106,7 +107,7 @@
@@ -116,8 +117,6 @@
else
/* reset worked, takes time... */
@@ -145,7 +144,7 @@
c = point.c;
dc = point.downc;
dseg_get(&wat, &value, r, c);
- dseg_get(&wat, &value_sfd, dr, dc);
+ dseg_get(&wat, &valued, dr, dc);
@@ -162,7 +161,7 @@
cseg_get(&alt, &ele, r, c);
@@ -172,7 +171,6 @@
bseg_get(&worked, &in_val, r_nbr, c_nbr);
if (in_val == 0) {
cseg_get(&alt, &ele_nbr, r_nbr, c_nbr);
weight[ct_dir] =
mfd_pow(((ele -
@@ -252,16 +250,13 @@
- G_warning(_("3 cumulative proportion not 1.0 but %f"),
prop);
- valued =
- ABS(value_sfd) +
if (value > 0) {
if (valued > 0)
valued += value;
@@ -282,7 +277,7 @@
bseg_get(&swale, &is_swale, r, c);
+ if (is_swale || (int)valued >= threshold) {
bseg_put(&swale, &one, dr, dc);
else {
@@ -294,8 +289,8 @@
if (workedon)
- do_points);
seg_close(&astar_pts);
diff -ruP r.watershed/seg/no_stream.c r.watershed.mfd/seg/no_stream.c
--- r.watershed/seg/no_stream.c 2008-12-09 09:26:58.000000000 +0100
+++ r.watershed.mfd/seg/no_stream.c 2008-12-08 15:55:37.000000000 +0100
@@ -6,8 +6,8 @@
double slope;
- CELL downdir, asp_value, hih_ele, new_ele, aspect;
+ CELL downdir, asp_value, hih_ele, new_ele, aspect, value;
while (1) {
@@ -18,14 +18,13 @@
cseg_get(&asp, &aspect, r, c);
- dseg_get(&wat, &value, r, c);
- if (value < 0)
- value = -value;
+ dseg_get(&wat, &dvalue, r, c);
+ if (dvalue < 0)
+ dvalue = -dvalue;
uprow = r;
upcol = c;
