[GRASS-dev] Re: doxygen problem - Re: [GRASS-SVN] r33243 -
grass/branches/develbranch_6/lib
Glynn Clements
glynn at gclements.plus.com
Sun Dec 14 08:54:00 EST 2008
Markus Neteler wrote:
> Maybe mv fails and it must be 'mv -f'? The cronjob runs under
> my user login on xblade14 and mv is an alias to 'mv -v'. I don't
> know if aliases are picked up by user cronjobs.
They aren't, nor is the user's environment from /etc/profile,
~/.bash_profile, etc.
In any case, aliases only work in shells where they are explicitly
defined (in practice, this means interactive shells which source
~/.bashrc). They aren't propagated to child processes (e.g. scripts,
make, etc).
