[GRASS-dev] Re: doxygen problem - Re: [GRASS-SVN] r33243 - grass/branches/develbranch_6/lib
Markus Neteler neteler at osgeo.org
Sun Dec 14 11:29:07 EST 2008
On Sun, Dec 14, 2008 at 2:54 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> Maybe mv fails and it must be 'mv -f'? The cronjob runs under
>> my user login on xblade14 and mv is an alias to 'mv -v'. I don't
>> know if aliases are picked up by user cronjobs.
> They aren't, nor is the user's environment from /etc/profile,
> ~/.bash_profile, etc.
> In any case, aliases only work in shells where they are explicitly
> defined (in practice, this means interactive shells which source
> ~/.bashrc). They aren't propagated to child processes (e.g. scripts,
> make, etc).
Thanks, then there must be some magic elsewhere.
For now, I force the removal and retrieval of the lib/vector/vectorlib.dox
file to get rid of the left-over change.
Currently ok, we'll see next Sunday if the fix persists.
Markus
