[GRASS-dev] Re: [GRASS GIS] #82: new module: v.to.3d
GRASS GIS trac at osgeo.org
Sun Dec 14 21:33:07 EST 2008
  Reporter:  hamish       |       Owner:  martinl
      Type:  task         |      Status:  assigned
  Priority:  major        |   Milestone:  6.4.0
 Component:  Vector       |     Version:  svn-develbranch6
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:3 martinl]:
 > I am not sure which module to use for reverse transformation
 > (3D->2D).
 points, centroids: v.out.ascii | v.in.ascii (without -z or z=). then you'd
 need to copy+merge tables adding in the new z column.
 polyfeatures: v.out.ascii format=standard | awk to strip away the third
 column | v.in.ascii format=standard. I think layer/cat setting at end of
 each feature is ok as it is always like "1 1", never a third column.
 AFAICT there's no way to keep the data in that 3rd column, as a line can
 only hold a single attribute/cat. the user can summarize with v.univar if
 they want that...?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/82#comment:5>
