[GRASS-dev] Re: [GRASS GIS] #82: new module: v.to.3d
Dylan Beaudette
dylan.beaudette at gmail.com
Sun Dec 14 22:13:14 EST 2008
> Reporter: hamish | Owner: martinl
> Type: task | Status: assigned
> Priority: major | Milestone: 6.4.0
> Component: Vector | Version: svn-develbranch6
> Resolution: | Keywords:
> Platform: Unspecified | Cpu: Unspecified
> Comment (by hamish):
I am wondering-- would it be simpler to add a flag to v.drape for
converting vectors to 3D, with all z-values set to some constant? Or
is that not what v.to.3d does?
Dylan
> Replying to [comment:3 martinl]:
> > I am not sure which module to use for reverse transformation
> > (3D->2D).
> points, centroids: v.out.ascii | v.in.ascii (without -z or z=). then you'd
> need to copy+merge tables adding in the new z column.
> polyfeatures: v.out.ascii format=standard | awk to strip away the third
> column | v.in.ascii format=standard. I think layer/cat setting at end of
> each feature is ok as it is always like "1 1", never a third column.
> AFAICT there's no way to keep the data in that 3rd column, as a line can
> only hold a single attribute/cat. the user can summarize with v.univar if
> they want that...?
> Hamish
> Ticket URL: <https://trac.osgeo.org/grass/ticket/82#comment:5>
> GRASS GIS <http://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
