[GRASS-dev] [GRASS GIS] #400: Bogous SQL error message handling in
db_execute_immediate
trac at osgeo.org
Mon Dec 15 07:23:06 EST 2008
#400: Bogous SQL error message handling in db_execute_immediate
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Database | Version: svn-develbranch6
Keywords: | Platform: Unspecified
Cpu: Unspecified |
I was trying to import shapefile with v.in.ogr and it failed while trying
to create database. Only problem - there was no meaningfull error message
displayed. Using same SQL expression with db.execute also failed to
produce readable error message. After subsequent runs I once got some
wired character as error message most likely coming from bogous printf
statement argument. Still I was not able to identify origin of that error
message to check printf arguments.[[BR]]
Revision: 34900 make distclean && make
$ echo "create table gps_pents_osl (cat integer, SHAPEID integer, ELE
double precision, NAME varchar ( 80 ), DESC varchar ( 80 ), AUGST double
precision)" | db.execute
DBMI-DBF driver error:
SQL parser error: �۷
in statement:
create table gps_pents_osl (cat integer, SHAPEID integer, ELE double
precision)
Error in db_execute_immediate()
Ticket URL: <http://trac.osgeo.org/grass/ticket/400>
