[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Tue Dec 16 09:55:09 EST 2008
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Platform: Unspecified | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:27 mmetz]:
> BTW, it seems that some changes in the patch are there because the
original code was not indented with grass_indent.sh.
It's best if you can avoid mixing substantial changes and formatting
changes in the same patch. If the code wasn't formatted either preserve
the original formatting (or use e.g. "svn diff -x -b" to ignore whitespace
changes) or re-format the code first.
FWIW, I've reformatted r.out.gdal in r34914.
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:28>
