[GRASS-dev] Re: [GRASS GIS] #295: region corrupted
trac at osgeo.org
Wed Dec 17 02:22:45 EST 2008
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by hamish):
ok, so it is a matter of expectations.
how to improve the wording?
* I think all the "Zoom display to ..." menu items can stay as-is, as it
is not as critical if the display region is slightly askew. -- it's just a
visual thing. So vague language is ok here.
* My suggestion to solve this ticket is to reword "'''Set computational
region extents to match display'''". It is critical to have the
computational region set cleanly for computations, and g.region -a is
needed to avoid sloppy regions set from the display. So crisp language is
needed to explain this.
Replace "to match" with "from"? that makes it more technically correct,
but still doesn't address the user expectation issue very well.
Replace "Set" with "Align"? That puts forward the idea that the two grids
are still somewhat independent.
how about: "Align computational region to current display"?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/295#comment:8>
