[GRASS-dev] error in r.univar2?
G. Allegri giohappy at gmail.com
Wed Dec 17 10:41:02 EST 2008
I had a problem while I was compiling from develbranch6:
r.univar_main.c: In function 'set_params':
r.univar_main.c:37: error: 's' undeclared (first use in this function)
r.univar_main.c:37: error: (Each undeclared identifier is reported only once
r.univar_main.c:37: error: for each function it appears in.)
r.univar_main.c:38: error: expected ';' before 'param'
make[2]: *** [OBJ.i686-pc-linux-gnu/r.univar_main.o] Error 1
Looking at r.univar_main.c I see this at row 37:
param.percentile->options = "0-100";s
Is the "s" corrected??? It is the cause of the compilation failure...
Giovanni
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20081217/53536c37/attachment.html
