[GRASS-dev] error in r.univar2?
Martin Landa
landa.martin at gmail.com
Wed Dec 17 11:43:33 EST 2008
2008/12/17 G. Allegri <giohappy at gmail.com>:
> I had a problem while I was compiling from develbranch6:
> r.univar_main.c: In function 'set_params':
> r.univar_main.c:37: error: 's' undeclared (first use in this function)
> r.univar_main.c:37: error: (Each undeclared identifier is reported only once
> r.univar_main.c:37: error: for each function it appears in.)
> r.univar_main.c:38: error: expected ';' before 'param'
> make[2]: *** [OBJ.i686-pc-linux-gnu/r.univar_main.o] Error 1
> Looking at r.univar_main.c I see this at row 37:
> param.percentile->options = "0-100";s
> Is the "s" corrected??? It is the cause of the compilation failure...
no, it's typo. Are you sure that you are not working with locally
modified copy of the file?
svn revert r.univar_main.c
make
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
