[GRASS-dev] error in r.univar2?
G. Allegri
giohappy at gmail.com
Wed Dec 17 11:45:30 EST 2008
Sorry, I was going to answer. It was a typo in my version... don't know why
but svn update has made it!
thx anyway
2008/12/17 Martin Landa <landa.martin at gmail.com>
> Hi,
> 2008/12/17 G. Allegri <giohappy at gmail.com>:
> > I had a problem while I was compiling from develbranch6:
> > r.univar_main.c: In function 'set_params':
> > r.univar_main.c:37: error: 's' undeclared (first use in this function)
> > r.univar_main.c:37: error: (Each undeclared identifier is reported only
> once
> > r.univar_main.c:37: error: for each function it appears in.)
> > r.univar_main.c:38: error: expected ';' before 'param'
> > make[2]: *** [OBJ.i686-pc-linux-gnu/r.univar_main.o] Error 1
> > Looking at r.univar_main.c I see this at row 37:
> > param.percentile->options = "0-100";s
> > Is the "s" corrected??? It is the cause of the compilation failure...
> no, it's typo. Are you sure that you are not working with locally
> modified copy of the file?
> svn revert r.univar_main.c
> make
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa<http://gama.fsv.cvut.cz/%7Elanda>*
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20081217/bd1ec133/attachment.html
