[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not work
GRASS GIS trac at osgeo.org
Thu Dec 18 04:12:03 EST 2008
  Reporter:  helena       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  critical     |   Milestone:  6.4.0
 Component:  Raster       |     Version:  svn-trunk
Resolution:               |    Keywords:  r.out.gdal, tiff
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by mmetz):
 Replying to [comment:29 hamish]:
 > FWIW, it was just minor whitespace on roughly 5 lines. I don't think  it
 is necessary to run intent compulsively as long as the whitespace doesn't
 get too abused.
 The question is, keep the GRASS source code in standard format yes or no?
 According to the discussion on it and to SUBMITTING, the answer is
 something like "YES, we had a long discussion on it, reformatting the
 whole source code was a major change, now please be so kind as to keep the
 code in the standard format" and not "Yes, but a little deviation here and
 there doesn't harm". No offense! My patch would introduce some new code,
 that's why I ran indent on it, otherwise I would have been told to do so
 first before proposing a patch.
 Justification for the patch: the TODO's in the code have been attended to;
 that would avoid quite a few of the problems reported in this very long
 ticket and IMHO the module could be regarded as working all right if these
 TODO's are solved.
 I replaced the attached patch with a new patch against the newly formatted
 r.out.gdal
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:30>
