[GRASS-dev] Re: [GRASS GIS] #344: TODO: move high priority incubated modules into main
GRASS GIS trac at osgeo.org
Thu Dec 18 05:54:24 EST 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  task     |      Status:  new
  Priority:  blocker  |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:
  Platform:  All      |         Cpu:  All
Comment (by martinl):
 Replying to [comment:17 hamish]:
 > I notice that the column names are case sensitive; and could the column
 check be moved before any output? and the error message should be like
 "column <%s> not found" ?
 > GRASS64> v.out.ascii in=hospitals col=name,phone
 > ERROR: Column <name>: unsupported data type
 > 697237.5638615|182012.65540056|1GRASS64>
 fixed in r34926 (6.4) r34927 (7.0).
Ticket URL: <https://trac.osgeo.org/grass/ticket/344#comment:19>
