[GRASS-dev] r.watershed question
Markus Metz
markus.metz.giswork at googlemail.com
Sat Dec 20 03:59:15 EST 2008
Michael Barton wrote:
> Should r.watershed be giving negative accumulation values?
Yes. Negative accumulation values indicate that these cells receive
offmap inflow or inflow from a MASKed area from somewhere upstream. This
has always been the case for flow accumulation output. Negative flow
accumulation can be interpreted as "at least so many cells drain into
this cell, but probably more cells that were not included in the
region/unMASKed area". State that more clearly in the manpage?
Regards,
Markus M
