[GRASS-dev] r.watershed question
Michael Barton michael.barton at asu.edu
Sat Dec 20 10:17:49 EST 2008
Thanks for the information. I did look through the docs but didn't see
this. I guess I missed it.
So...
r.mapcalc positive_accum=if(accum_map<0,accum_map*-1,accum_map)
...would produce a normal flow accumulation map, but one that
underestimates flow in some areas?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Dec 20, 2008, at 1:59 AM, Markus Metz wrote:
> Michael Barton wrote:
>> Should r.watershed be giving negative accumulation values?
> Yes. Negative accumulation values indicate that these cells receive
> offmap inflow or inflow from a MASKed area from somewhere upstream.
> This has always been the case for flow accumulation output. Negative
> flow accumulation can be interpreted as "at least so many cells
> drain into this cell, but probably more cells that were not included
> in the region/unMASKed area". State that more clearly in the manpage?
> Regards,
> Markus M
