[GRASS-dev] nviz python thoughts
Sat Dec 20 12:08:27 EST 2008
William Kyngesburye wrote:
> I was thinking that all Python stuff (yes, I know it's experimental)
> that compiles and runs on OSX should be so without fuss for the 6.4
> release.  In particular NVIZ.  Currently, to get libnviz to compile we
> must disable/delete render.c, which makes the not-working-yet-on-OSX
> nviz_cmd fail to compile.
> If only nviz_cmd needs the render.c functions, could render.c be moved
> to the nviz_cmd folder?  This would let libnviz compile on OSX and
> make the wx GUI nviz operational.  nviz_cmd would still fail to
> compile as expected, without affecting the GUI nviz compilation.
Only nviz_cmd needs it at the moment, but the code is sufficiently
general that it belongs in the library.
Remind me: what is the specific problem with compiling it on OSX?
