[GRASS-dev] NVIZ problem on Mac
Michael Barton
michael.barton at asu.edu
Sat Dec 20 12:41:23 EST 2008
On Dec 20, 2008, at 10:00 AM, <grass-dev-request at lists.osgeo.org> <grass-dev-request at lists.osgeo.org
> wrote:
> Date: Sat, 20 Dec 2008 10:42:40 -0600
> From: William Kyngesburye <woklist at kyngchaos.com>
> Subject: Re: [GRASS-dev] NVIZ problem on Mac
> To: Michael Barton <michael.barton at asu.edu>
> Cc: grass developers <grass-dev at lists.osgeo.org>
> Message-ID: <AEFEE6DF-DA05-4949-B476-0DF87BC3EBB3 at kyngchaos.com>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> On Dec 20, 2008, at 12:32 AM, Michael Barton wrote:
>> On Dec 19, 2008, at 10:34 PM, William Kyngesburye wrote:
>>> I think this must be a problem with OS X. Both a version compiled
>>> last week and a version compiled in September, in which NVIZ *did*
>>> work now fail. I'll copy the Mac error report below. I am running
>>> 10.5.6 now. I have tried this against a self-compiled TclTk aqua
>>> and the ActiveStates version.
>> Binary Images:
>> 0xa1000 - 0x11ffef com.tcltk.tcllibrary 8.4.7 b (8.4.7 b)
>> <fd41897f36de9271d601298eaf7cdf4b> /System/Library/Frameworks/
>> Tcl.framework/Versions/8.4/Tcl
>> 0xb000000 - 0xb0adfeb com.tcltk.tklibrary 8.4.7 b (8.4.7 b)
>> <9e3b1ff29ce1a8ada6e6354a43f11c5b> /System/Library/Frameworks/
>> Tk.framework/Versions/8.4/Tk
> This problem again - it's linking the system tcltk 8.4.
> There's a note to the OSX source readme to symlink the ActiveTcl
> framework to /usr/local. This should avoid accidental system tcltk
> linking:
> sudo ln -sf /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl /usr/
> local/lib/libtcl.dylib
> local/lib/libtcl8.5.dylib
> libtclstub8.5.a /usr/local/lib/libtclstub8.5.a
> sudo ln -sf /Library/Frameworks/Tk.framework/Versions/8.5/Tk /usr/
> local/lib/libtk.dylib
> local/lib/libtk8.5.dylib
> libtkstub8.5.a /usr/local/lib/libtkstub8.5.a
> sudo ln -sf tclsh8.5 /usr/local/bin/tclsh
> sudo ln -sf wish8.5 /usr/local/bin/wish
> (I added the tclsh and wish symlinks recently, haven't comitted yet,
> to help get the GUI to use 8.5)
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
Thanks for troubleshooting this William.
I can't figure out why this is trying to use the system TclTk when 1)
it was compiled against 8.5, 2) GRASS_WISH is set to wish8.5 so that
all the *rest* of the GUI uses 8.5 instead of 8.4, and 3) the same
version that worked fine a few weeks ago stopped working.
Michael
