[GRASS-dev] wingrass640
Colin Nielsen
colin.nielsen at gmail.com
Sun Dec 21 10:16:13 EST 2008
I also had to add a compile regex from src for configure to work. I
also updated various other dependencies and msys/mingw itself since I
got a missing "bcopy" error. That is fixed now but I think the
difference in updates between when I first ran configure and make on
the grass64 source and now is causing problems.
I get the following error:
make[2]: *** No rule to make target
`/usr/local/src/grass-6.4.0/dist.i686-pc-mingw32/lib/libgrass_vect.dll',
needed by `/usr/local/src/grass-6.4.0/dist.i686-pc-mingw32/bin/v.sample.exe'.
Stop.
make[2]: Leaving directory `/usr/local/src/grass-6.4.0/vector/v.sample'
This is just an example, I get it for every module as far as I can tell.
I re-ran configure after all my updates, also I tried 'make clean'
before running make again but no luck so far.
-Colin
On Sun, Dec 21, 2008 at 8:35 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> I am currently trying to compile GRASS (releasebranch_6_4) under MS
> Windows [1].
> TODO:
> * compile with regex
> * compile wxGUI digitizer
> * and optionally compile wxGUI Nviz extension
> wxGUI seesm to work (add raster and vector layer, render map).
> It would be also good to modify Windows installer: add to the menu
> (and desktop) two items
> * TCLTK GRASS
> * WX GRASS
> for easy testing new wxGUI interface under MS Windows.
> Martin
> [1] http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html#GRASS
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
