[GRASS-dev] wingrass640
Glynn Clements
glynn at gclements.plus.com
Sun Dec 21 13:19:10 EST 2008
Colin Nielsen wrote:
> I also had to add a compile regex from src for configure to work. I
> also updated various other dependencies and msys/mingw itself since I
> got a missing "bcopy" error. That is fixed now but I think the
> difference in updates between when I first ran configure and make on
> the grass64 source and now is causing problems.
> I get the following error:
> make[2]: *** No rule to make target
> `/usr/local/src/grass-6.4.0/dist.i686-pc-mingw32/lib/libgrass_vect.dll',
This means that vector library failed to compile. Do you get an error
make -C lib/vector
