[GRASS-dev] wingrass640
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sun Dec 21 17:52:22 EST 2008
On Sun, 21 Dec 2008, Martin Landa wrote:
> Hi,
> I am currently trying to compile GRASS (releasebranch_6_4) under MS
> Windows [1].
> TODO:
> * compile with regex
I can report it works fine with the Gnuwin32 regex packages. Another issue
is that Cairo support in the 6.4 configure script requires the pkg-config
command which isn't generally available on Windows. But the 7.0 configure
script doesn't require pkg-config and in any case Cairo support isn't
particularly important for 6.4 so I don't think this needs to be
addressed.
> It would be also good to modify Windows installer: add to the menu
> (and desktop) two items
> * TCLTK GRASS
> * WX GRASS
Something else that might be worth investigating would be to implement an
option to select the language. I've found that it can easily be done by
setting the environment variable LC_ALL to the country code (if compiled
with NLS support - Gnuwin32 intl packages work fine here) but the average
Windows user may not know how to set an environment variable and I wonder
is there some standard way applications using NLS support on Windows set
the language.
Paul
