[GRASS-dev] r.watershed fails in 6.4 SVN
Michael Barton michael.barton at asu.edu
Sun Dec 21 19:22:48 EST 2008
I just updated and compiled today.
r.watershed compiles without problems, but it fails when you try to
run it. It worked OK yesterday. Here is the error from Spearfish.
GRASS 6.4.svn (Spearfish60_test):~ > r.watershed
elevation=elevation.dem accumulation=atest_delete1
ERROR: USAGE for basin delineation:
        /Applications/Grass/GRASS-6.4.app/Contents/MacOS/etc/
r.watershed.ram
        -4 el=elevation_map t=swale_threshold [ov=overland_flow_map]
        [dr=drain_direction_map] [de=depression_map]
[ac=accumulation_map]
        [di=display_map] ba=watershed_basin_map [se=stream_segment_map]
        USAGE for ARMSED FILE creation:
r.watershed.ram
        [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map]
        [di=display_map] [ba=watershed_basin_map]
        ha=half_basin_map ar=ARMSED_file_name
        USAGE for slope length determination:
r.watershed.ram
        [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map]
        [de=depression_map] [ac=accumulation_map] [di=display_map]
        [ms=max_slope_length] [ob=overland_blocking_map]
        [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map]
        [sd=slope_deposition value or map]
WARNING: Subprocess failed with exit code 256
WARNING: category information for [atest_delete1] in [PERMANENT]
missing or
          invalid
Same (not very informative) error if I use -s or specify ls.factor for
the output
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20081221/369687a7/attachment-0001.html
