[GRASS-dev] r.watershed fails in 6.4 SVN
Dylan Beaudette
dylan.beaudette at gmail.com
Sun Dec 21 20:33:50 EST 2008
On Sun, Dec 21, 2008 at 4:22 PM, Michael Barton <michael.barton at asu.edu> wrote:
> I just updated and compiled today.
> r.watershed compiles without problems, but it fails when you try to run it.
> It worked OK yesterday. Here is the error from Spearfish.
> GRASS 6.4.svn (Spearfish60_test):~ > r.watershed elevation=elevation.dem
> accumulation=atest_delete1
> ERROR: USAGE for basin delineation:
> /Applications/Grass/GRASS-6.4.app/Contents/MacOS/etc/r.watershed.ram
> -4 el=elevation_map t=swale_threshold [ov=overland_flow_map]
> [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map]
> [di=display_map] ba=watershed_basin_map [se=stream_segment_map]
> USAGE for ARMSED FILE creation:
> [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map]
> [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map]
> ha=half_basin_map ar=ARMSED_file_name
> USAGE for slope length determination:
> [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map]
> [de=depression_map] [ac=accumulation_map] [di=display_map]
> [ms=max_slope_length] [ob=overland_blocking_map]
> [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map]
> [sd=slope_deposition value or map]
> WARNING: Subprocess failed with exit code 256
> WARNING: category information for [atest_delete1] in [PERMANENT] missing or
> invalid
> Same (not very informative) error if I use -s or specify ls.factor for the
> output
> Michael
> ____________________
Hmmm.. Works for me, same data, same incantation.
r34983 in Debian/Unstable - x86
Cheers,
Dylan
PS: looks like now would be a good time to get the test suite back online...
