[GRASS-dev] Re: [GRASS GIS] #399: Added "backlink" functionality to
r.walk, r.cost & r.drain
trac at osgeo.org
Sun Dec 21 20:48:38 EST 2008
#399: Added "backlink" functionality to r.walk, r.cost & r.drain
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by dylan):
r.cost.patch applies and compiles against GRASS64-SVN r34983
r.drain patch: error on applying to documentation, does not compile
(Stripping trailing CRs from patch.)
patching file main.c
patching file description.html
Hunk #4 FAILED at 208.
1 out of 4 hunks FAILED -- saving rejects to file description.html.rej
main.c: In function â:
main.c:697: error: â undeclared (first use in this function)
main.c:697: error: (Each undeclared identifier is reported only once
main.c:697: error: for each function it appears in.)
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error
r.walk.patch: applies with one error, and compiles
Hunk #4 FAILED at 149.
patching file stash.h
Ticket URL: <http://trac.osgeo.org/grass/ticket/399#comment:3>
