[GRASS-dev] Re: [GRASS GIS] #399: Added "backlink" functionality to r.walk, r.cost & r.drain
GRASS GIS trac at osgeo.org
Sun Dec 21 21:52:44 EST 2008
  Reporter:  cnielsen     |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  Raster       |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  All          |         Cpu:  All
Comment (by glynn):
 Replying to [comment:3 dylan]:
 > r.cost.patch applies and compiles against GRASS64-SVN r34983
 > r.drain patch: error on applying to documentation, does not compile
 > patching file description.html
 > Hunk !#4 FAILED at 208.
 > r.walk.patch: applies with one error, and compiles
 > Hunk !#4 FAILED at 149.
 Both of these are due to the expanded $Date$ at the bottom of the file.
 > main.c: In function â:
 > main.c:697: error: â undeclared (first use in this function)
 > main.c:697: error: (Each undeclared identifier is reported only once
 > main.c:697: error: for each function it appears in.)
 > make: *** [OBJ.i686-pc-linux-gnu/main.o] Error
 I don't know what happened to your comment (cut/paste issue?), but this
 should read:
 main.c: In function `drain_cost':
 main.c:697: error: `dir_name' undeclared (first use in this function)
 Indeed, dir_name is local to main(), so it isn't visible in drain_cost().
Ticket URL: <http://trac.osgeo.org/grass/ticket/399#comment:4>
