[GRASS-dev] compile errors for GRASS 7 in Mac OS X
    Glynn Clements
    glynn at gclements.plus.com
    Sun Dec 21 21:23:14 EST 2008
Michael Barton wrote:
> I just tried compiling GRASS 7 with OS X. Most went fine. I got a few
> errors
> Error in...
> /Users/cmbarton/grass_dev/grass7_src/lib/proj
> Doesn't recognize the NAD2BIN environmental variable
> Had to create symlink to /Library/Frameworks/PROJ.framework/Programs/
> nad2bin in /usr/local
> Then it compiled OK
Fixed in r34985.
> cmb-MBP-2:grass7_src cmbarton$ cd ./raster/r.statistics3
> cmb-MBP-2:r.statistics3 cmbarton$ make
> gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/
> include  -arch i386 -Os    -DPACKAGE=\""grassmods"\"   -I/Users/
> cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.6.0/include -o
> OBJ.i386-apple-darwin9.6.0/main.o -c main.c
> main.c:43: error: �fmin� redeclared as different kind of symbol
> main.c:43: error: �fmax� redeclared as different kind of symbol
> make: *** [OBJ.i386-apple-darwin9.6.0/main.o] Error 1
> A bug that needs fixing I guess
Fixed in r34984.
> Error in...
> /Users/cmbarton/grass_dev/grass7_src/macosx/app
> cd to ./macosx and ran make. No errors. Something in the make files
> messed up?
Maybe something is returning a non-zero exit code? If it performed its
intended task, it probably won't get run if you run make again.
