[GRASS-dev] compile errors for GRASS 7 in Mac OS X
Sun Dec 21 22:58:04 EST 2008
William Kyngesburye wrote:
> > /Users/cmbarton/grass_dev/grass7_src/macosx/app
> > cd to ./macosx and ran make. No errors. Something in the make files
> > messed up?
> I missed this.  Did you look back in the terminal to see what the
> error was?
> If it happens again, don't cd to macosx and make, but check the
> terminal scrollback first.
Better still, redirect make output:
	make &> build.log
Otherwise, your terminal needs a very large scrollback buffer. For me,
build.log comes to ~11,000 actual lines, or ~30,000 after wrapping to
80 columns.
Although, the macosx directory has the advantage of being right at the
end of the build process.
