[GRASS-dev] mac error in GRASS 7 compiling
Mon Dec 22 13:30:52 EST 2008
William Kyngesburye wrote:
> Looks like Glynn's r33038 messed it up.  I'll have to look at it to
> get it working again.
> Glynn: is OBJDIR not used now, or is there a different way of
> specifying custom OBJDIR/targets?  I'll take a closer look later at
> other parts of GRASS for examples.
I suspect the problem is that some of the files in $(MOD_OBJS) aren't
object files. If that ever worked, it was coincidence.
You need to add an rule which will force $(OBJDIR)/Info.plist to be
built, e.g.:
$(APPDIR)/Info.plist: $(OBJDIR)/Info.plist
	-$(INSTALL_DATA) $< $@
You also need to make $(APPDIR)/Info.plist as part of the top-level
macosxapp rule. One complication is the need to ensure that $(OBJDIR)
is created first, even in parallel builds, and it seems we can't rely
upon make (particularly the OSX version) supporting order-only
dependencies.
I suggest replacing the top-level macosxapp rule with the following:
NIBSRC := $(wildcard English.lproj/MainMenu.nib/*)
NIBDST := $(patsubst English.lproj/%,$(APPDIR)/English.lproj/%,$(NIBSRC))
FILES = \
	$(APPDIR)/MacOS/etc/build_html_user_index.sh \
	$(APPDIR)/MacOS/etc/build_gui_user_menu.sh \
	${APPDIR}/Resources/app.icns \
	$(APPDIR)/Info.plist \
	$(APPDIR)/PkgInfo \
	$(APPDIR)/Resources/Scripts/GRASS.scpt \
	$(APPDIR)/MacOS/grass.sh \
	$(APPDIR)/MacOS/GRASS \
	$(NIBDST)
macosxapp:
	-$(MAKE_DIR_CMD) $(OBJDIR)
	-$(MAKE_DIR_CMD) $(APPDIR)/Resources/Scripts
	-$(MAKE_DIR_CMD) $(APPDIR)/MacOS/scripts
	-$(MAKE_DIR_CMD) $(APPDIR)/MacOS/etc
	-$(MAKE_DIR_CMD) $(APPDIR)/English.lproj/MainMenu.nib
	$(MAKE) $(FILES)
${APPDIR}/Resources/app.icns: app.icns
$(APPDIR)/English.lproj/%: English.lproj/%
$(APPDIR)/PkgInfo: PkgInfo
$(APPDIR)/Resources/Scripts/GRASS.scpt: (OBJDIR)/GRASS.scpt
$(APPDIR)/MacOS/grass.sh: $(OBJDIR)/grass.sh
	$(INSTALL) $< $@
$(APPDIR)/MacOS/etc/%.sh: %.sh
	$(INSTALL) $< $@
BTW, is there a reason that main.m isn't called main.c?
