[GRASS-dev] 6.4 Nviz Windows problems
Tue Dec 23 00:55:45 EST 2008
Paul Kelly wrote:
> >> I had a problem compiling nviz from the 6.4 release branch on Windows,
> >> with unrecognised Tcl/Tk symbols. Reverting r32244 to put the Tcl/Tk
> >> library flags in among the other library linking flags seems to fix it:
> >> http://trac.osgeo.org/grass/changeset/32244
> >> I haven't committed as I don't understand the reason for that change.
> > $(XTRA_LDFLAGS) definitely should go after $(ARCH_OBJS) and
> > $(SURFLIB). Otherwise, it won't work if either the Tcl/Tk or OpenGL
> > libraries are static libraries.
> Yes, I was using static Tcl/Tk. Markus has fixed this now and I can
> confirm the fix works.
> >> Trying to run nviz brings up a further error - see attached -
> >> unfortunately no time to look into it further now.
> > I can't reproduce this. Does the file appear to be valid?
> No - it's not there actually. Didn't take much further looking into... the
> culprit seems to be r32173:
> http://trac.osgeo.org/grass/changeset/32173
> (-L option added to find command-line). The Msys find doesn't seem to have
> the -L option - but perhaps it is just a version issue? find --version
> reports:
> GNU find version 4.1
FWIW, -L is POSIX:
	http://www.opengroup.org/onlinepubs/009695399/utilities/find.html
It may be that MSys dropped the option due to Windows not having
symlinks, although silently ignoring it would have been better.
7.0 uses $(wildcard ...) instead of "find". That could be used, or
alternatively:
ifneq ($(strip $(MINGW)),)
	FIND = find
else
	FIND = find -L
endif
