[GRASS-dev] Re: [GRASS GIS] #128: NVIZ fails to load vector points
without other map
trac at osgeo.org
Wed Dec 31 07:55:14 EST 2008
#128: NVIZ fails to load vector points without other map
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: reopened
Priority: major | Milestone: 6.4.0
Component: NVIZ | Version: svn-trunk
Resolution: | Keywords: nviz
Platform: Unspecified | Cpu: Unspecified
Changes (by marisn):
* status: closed => reopened
* resolution: worksforme =>
Comment:
This bug still is NOT fixed. Reproduceable with recent 6.4 release branch.
Michael: You are using wrong steps to reproduce this issue. Please use
following steps:
v.random -z output=point3d n=100 zmin=1000 zmax=2000
nviz points=point3d
Vector map <point3d at vectdel> loaded (100 points)
Failed to initialize TTM buffer manager. Falling back to classic.
Error in startup script: integer value too large to represent
while executing
"expr int($curr * 1)"
(procedure "Nv_mkFloatScale" line 16)
invoked from within
"Nv_mkFloatScale $Nv_(HEIGHT_SLIDER) v height $max $min $val update_height
1"
(procedure "mk_hgt_slider" line 12)
invoked from within
"mk_hgt_slider $BASE.midf"
(procedure "mkmainPanel" line 144)
invoked from within
"mk$name\Panel $path"
invoked from within
"if [catch {set Nv_($path)}] {
set file panel_$name.tcl
set Nv_($path) [mk$name\Panel $path]
(procedure "Nv_force_panel" line 8)
invoked from within
"Nv_force_panel main"
(procedure "Nv_makeGUI" line 194)
invoked from within
"Nv_makeGUI $Nv_(AREA)"
(file "/home/marisn/soft/grass64_release/dist.i686-pc-linux-
gnu/etc/nviz2.2/scripts/nviz2.2_script" line 1052)
Ticket URL: <http://trac.osgeo.org/grass/ticket/128#comment:13>
