[GRASS-dev] erratic behavior of v.in.ascii with WinGRASS
Michael Barton
michael.barton at asu.edu
Mon Feb 4 17:37:39 EST 2008
I've run into a problem running v.in.ascii for WinGRASS importing an
ASCII points file. Sometimes it works OK. Other times, it causes a
Windows dbf.exe error but still gets the job done. In most cases, it
causes a dbf.exe error and only imports the first point--with a coor
error.
Here are a couple of other pieces of information.
It worked flawlessly on the Windows machine of a student in my lab,
when she imported points (with decimal degrees coordinates) into a
latlon region.
If the cat column is specified, it causes a Windows dbf.exe error on
all machines importing into a UTM/State Plane location. Sometimes only
the first point is imported and other cases all points are imported.
When the points are correctly imported, the dbf file is correctly built.
If the cat column is NOT specified, it works fine on some machines. On
others it causes a wish error and crashes the GUI (and hence GRASS).
But all the points are imported correctly. [In fact it crashes the
TclTk GUI on my MacBook when I upload points, but doesn't crash it on
at least some other Macs]. The associated dbf file is correctly built.
I've tested this in a classroom lab setting and on 2 different student
machines, using data from the North Carolina demo set
(schools_lu.txt), data from Spearfish, and data from elsewhere. I
initially thought that this might be a result of an installation
error, but given these results, it seems more like a problem with
v.in.ascii. The fact that it crashes the GUI on my MacBook is
especially suspicious in this regard.
Michael
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080204/59504521/attachment.html
