[GRASS-dev] erratic behavior of v.in.ascii with WinGRASS
Hamish hamish_b at yahoo.com
Mon Feb 4 21:23:46 EST 2008
Michael Barton wrote:
> I've run into a problem running v.in.ascii for WinGRASS importing an
> ASCII points file. Sometimes it works OK. Other times, it causes a
> Windows dbf.exe error but still gets the job done. In most cases, it
> causes a dbf.exe error and only imports the first point--with a coor
> error.
> Here are a couple of other pieces of information.
can you 1) run it with 'g.gisenv DEBUG=5' and 2) make the input file
and exact command line used available.
how about if you skip DB creation with '-t'?
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
